TwinTurbo.NET: Nissan 300ZX forum - Re: Run ECU codes, clean all connections and ohm test.....
Subject Re: Run ECU codes, clean all connections and ohm test.....
Posted by wrxfl on June 18, 2008 at 3:38 PM
  This message has been viewed 170 times.
In Reply To Run ECU codes, clean all connections and ohm test..... posted by Marc (NJ) on June 17, 2008 at 07:06 AM
Message It seems that the #5 cylinder is the issue. Doing a leakdown test/compression test now. Anything else I could check.....I'm thinking possibly the Crank Angle Sensor or the connector?
